How can i add more hard drive to owncloud?
Hi ,
my server couldn’t enough space , how to add other hard drive to owncloud ?
Thank !
You can either:
  1. Extend the storage space on your operation system (please use your favorite search engine to find the info how to do this)
  2. Include additional storages via the external storage app ownCloud Documentation Overview
Option 2. won’t give more space on your ownCloud instance and won’t raise the quota on your system. You would need to move your files to that external storage to make space free on your oC instance.
If you want to combine the storage of several disks, load volume manager is the keyword to look for: Logical volume management - Wikipedia
ok , i know it thank
