How can I simply disable “trusted domains”? I do not need this and it makes accessing owncloud behing my nginx reverse proxy difficult.
best wishes.
best wishes.
Hi Nadine_Bohr,
You cannot disable this. Maybe you don’t need it, but ownCloud requires it
Basically you enter all the IPs/Domains users will enter into their browsers accessing your cloud. You don’t have to consider any reverse proxy since the server will receive the passed Host variable. (I guess you do pass it in your nginx conf?)
See the docs: Config.php Parameters :: ownCloud Documentation
So actually why does it make accessing ownCloud difficult in context with your reverse proxy?
