Hi I really need help. I have been experiencing PDOException : SQLSTATE [42S02] Error error when installing owncloud. It says table or view not found 1146 table 'owncloud.oc_appconfig does not exist in /var/www/owncloud/lib/composer/Doctrine/DBAL/driver/PDO/Exception.php:18
I am using owncloud 10.9.1
running ubuntu 20.04.4 LTS and mariadb 15.1
I am getting the error every time I run occ maintenance:install
Hi …thanks for your response.
I did follow the instructions and everything went well. I later went on mess with the configuration by uninstalling mysql and reinstalling mariadb…so far every other code runs perfectly except anything with occ.
