- Follow guide on how to move data directory.
I moved the data folder to a mounted drive, and after following the guide i would be able to access my files as normal.
After following the guide i can see the files, but not download them. I can also not make new folders, or upload new files.
Operating system: Ubuntu 17.10
Web server: Nginx
PHP version: PHP 7.1 (PHP7.1-fpm)
ownCloud version: 10.0.7.2
Where did you install ownCloud from: ownCloud repository
Signing status (ownCloud 9.0 and above): No errors have been found.
"config": {
"updatechecker": false,
"instanceid": "ocndg7hio42q",
"trusted_domains": [
"cloud.marinescada.com"
"datadirectory": "\/mnt\/volume_lon1_01\/owncloud\/data\/",
"overwrite.cli.url": "https:\/\/cloud.marinescada.com",
"dbtype": "mysql",
"version": "10.0.7.2",
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"mysql.utf8mb4": true,
"logtimezone": "UTC",
"installed": true,
"updater.secret": "***REMOVED SENSITIVE VALUE***"
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.3.2
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_pdfviewer: 0.8.2
- files_sharing: 0.10.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- market: 0.2.4
- notifications: 0.3.2
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.3
- updatenotification: 0.2.1
Are you using encryption: yes
Browser: Firefox
Operating system: Windows 10
