is there guid for owncloud integrate with keycloak.
I setup keycloak, using openid auth for owncloud. In ‘http’ protocol, I can login and everything is OK. But in ‘https’ protocol, met PKCE
error ( more detail: PKCE error with cookie.samesite · Issue #219 · owncloud/openidconnect · GitHub). as suggestion, set cookie.samesite
it is no working. I am not sure if wrong config with my keycloak. need help. thanks.
how can i using this owncloud
follow this link GitHub - owncloud/openidconnect: OpenId Connect Integration for ownCloud, will did it
