I get the INVALID_HASH for .htaccess and I have no way of getting the old configuration of the owncloud. The operating system needed to be recovered from backups and they were older than files in the owncloud configuration. I don’t know if the current hash for .htaccess is for the current owncloud version.
Is the version 9.1.6 available for download?
How to convince owncloud to accept the .htaccees file?
- php occ integrity:check-core
The integrity test should pass
The test returns:
- INVALID_HASH:
- .htaccess:
- expected: ab5f4c44ba2f9c66f2ed25c3ad3d84660b2808cca11ffa8fe2778a648a054d8ada495a0bf4715dc873aac1efe8dfd92a72f9a24441d8f5240834e639325fd892
- current: cd513438eef6164a503c84bfcc3e933598dae3f43a2745f9bdf36615fd821d1213abd1e3ce42da7d8f948f3e39ca495679401e149f9daf2d0fe7f883527d18f4
- .htaccess:
CentOS 7.5.1804
Apache
Cannot login to ownCloud.
occ returns 9.1.6
Cannot login into ownCloud: Access forbidden CSRF check failed
<?php $CONFIG = array ( 'instanceid' => 'ociozheizcie', 'passwordsalt' => 'CFvalWVbgvvUNsxxSN0KLeGqnSa8VY', 'secret' => 'bidpgSWanq3CCVseYTcIT1OHdfencJMEYbSX7K7iicxKnSQ2', 'trusted_domains' => array ( 0 => 'XX.XX.XX', 1 => 'XX.XX.XX.XX', ), 'datadirectory' => '/var/ownclouddata', 'overwrite.cli.url' => 'https://XXX.XXXX.XXXl/owncloud', 'dbtype' => 'mysql', 'version' => '9.1.6.2', 'dbname' => 'clouddb', 'dbhost' => 'localhost', 'dbtableprefix' => 'oc_', 'dbuser' => 'XXXXXXXX', 'dbpassword' => 'XXXXXXXX', 'logtimezone' => 'UTC', 'installed' => true, 'mail_from_address' => 'owncloud.XX', 'mail_smtpmode' => 'smtp', 'mail_domain' => 'XX.XX', 'trashbin_retention_obligation' => 30, 'trashbin_auto_expire' => true, 'defaultapp' => 'files', 'remember_login_cookie_lifetime' => 3600, 'session_lifetime' => 3600, 'forcessl' => true, 'has_internet_connection' => true, 'log_rotate_size' => 104857600, 'logfile' => '/var/log/owncloud.log', 'loglevel' => 0, 'maintenance' => false, 'ldapIgnoreNamingRules' => false, 'ldapIgnoreNamingRules' => false, 'htaccess.RewriteBase' => '/owncloud', 'theme' => '', 'mail_smtpsecure' => 'tls', 'mail_smtpauthtype' => 'PLAIN', 'mail_smtpauth' => 1, 'mail_smtphost' => 'smtp.XX.XX', 'mail_smtpname' => 'owncloud.XX', 'mail_smtppassword' => 'XXXXXXXXX', ``` Log in to the web-UI with an administrator account and click on 'admin' -> 'Generate Config Report' -> 'Download ownCloud config report' This report includes the config.php settings, the list of activated apps and other details in a well sanitized form. or If you have access to your command line run e.g.: sudo -u www-data php occ config:list system from within your ownCloud installation folder *ATTENTION:* Do not post your config.php file in public as is. Please use one of the above methods whenever possible. Both, the generated reports from the web-ui and from occ config:list "trusted_domains": [ "exchange.fotonowy.pl", "XX.XX.XX.XX" ], "datadirectory": "\/var\/ownclouddata", "overwrite.cli.url": "https:\/\/exchange.XX.XX\/owncloud", "dbtype": "mysql", "version": "9.1.6.2", "dbname": "clouddb", "dbhost": "localhost", "dbtableprefix": "oc_", "dbuser": "***REMOVED SENSITIVE VALUE***", "dbpassword": "***REMOVED SENSITIVE VALUE***", "logtimezone": "UTC", "installed": true, "mail_from_address": "owncloud.xx", "mail_smtpmode": "smtp", "mail_domain": "XX.XX", "trashbin_retention_obligation": 30, "trashbin_auto_expire": true, "defaultapp": "files", "remember_login_cookie_lifetime": 3600, "session_lifetime": 3600, "forcessl": true, "has_internet_connection": true, "log_rotate_size": 104857600, "logfile": "\/var\/log\/owncloud.log", "loglevel": 0, "maintenance": false, "ldapIgnoreNamingRules": false, "htaccess.RewriteBase": "\/owncloud", "theme": "", "mail_smtpsecure": "tls", "mail_smtpauthtype": "PLAIN", "mail_smtpauth": 1, "mail_smtphost": "smtp.XX.XX", "mail_smtpname": "***REMOVED SENSITIVE VALUE***", "mail_smtppassword": "***REMOVED SENSITIVE VALUE***" consistently remove sensitive data. You still may want to review the report before sending. If done manually then it is critical for your own privacy to dilligently remove *all* host names, passwords, usernames, salts and other credentials before posting. You should assume that attackers find such information and will use them against your systems. ``` **List of activated apps:** ``` If you have access to your command line run e.g.: sudo -u www-data php occ app:list from within your ownCloud installation folder. ``` Enabled: - activity: 2.3.2 - comments: 0.3.0 - configreport: 0.1.1 - dav: 0.2.7 - federatedfilesharing: 0.3.0 - federation: 0.1.0 - files: 1.5.1 - files_pdfviewer: 0.8.1 - files_sharing: 0.10.0 - files_texteditor: 2.1 - files_trashbin: 0.9.0 - files_versions: 1.3.0 - files_videoplayer: 0.9.8 - firstrunwizard: 1.1 - gallery: 15.0.0 - notifications: 0.3.0 - provisioning_api: 0.5.0 - systemtags: 0.3.0 - templateeditor: 0.1 - updatenotification: 0.2.1 Disabled: - encryption - external - files_antivirus - files_external - user_external - user_ldap **Are you using external storage, if yes which one:** local/smb/sftp/... no **Are you using encryption:** yes/no no **Are you using an external user-backend, if yes which one:** LDAP/ActiveDirectory/Webdav/... ? none ``` With access to your command line run e.g.: sudo -u www-data php occ ldap:show-config from within your ownCloud installation folder Without access to your command line download the data/owncloud.db to your local computer or access your SQL server remotely and run the select query: SELECT * FROM `oc_appconfig` WHERE `appid` = 'user_ldap'; Eventually replace sensitive data as the name/IP-address of your LDAP server or groups. ``` ### Logs #### Web server error log ``` Insert your webserver log here ``` #### ownCloud log (data/owncloud.log) ``` Insert your ownCloud log here ``` #### Browser log ``` Insert your browser log here, this could for example include: a) The javascript console log b) The network log c) ... ```
