Smooth uploading file without error.
Uploading a file via web interface I get a small yellow pop up on the top saying "Internal Server Error". Refreshing the page, file have been saved.
Debian Jessie 8.8 - 3.16.0-4-amd64 #1 SMP Debian 3.16.43-2 (2017-04-30) x86_64 GNU/Linux
Apache 2.4.10
PostgreSQL 9.4.12
PHP 5.6.30-0+deb8u1
10.0.0.12
Fresh install.
Archive file.
"system": {
"instanceid": "oc8ixrmtnw6y",
"trusted_domains": [
"datadirectory": "\/var\/www\/my_domain\/data",
"overwrite.cli.url": "https:\/\/my_domain\/owncloud",
"dbtype": "pgsql",
"version": "10.0.0.12",
"dbname": "owncloud",
"dbhost": "localhost:5432",
"dbtableprefix": "oc_",
"logtimezone": "Europe\/Rome",
"installed": true,
"mail_smtpmode": "smtp",
"mail_domain": "gmail.com",
"mail_smtpauthtype": "LOGIN",
"mail_smtpauth": 1,
"mail_smtphost": "smtp.gmail.com",
"mail_smtpport": "587",
"mail_smtpsecure": "tls"
Enabled:
- activity: 2.3.3
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.2.8
- federatedfilesharing: 0.3.0
- federation: 0.1.0
- files: 1.5.1
- files_antivirus: 0.10.0.0
- files_external: 0.7.0
- files_pdfviewer: 0.8.1
- files_sharing: 0.10.0
- files_texteditor: 2.1
- files_trashbin: 0.9.0
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 15.0.0
- market: 0.1.0
- notifications: 0.3.0
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.1
- updatenotification: 0.2.1
Disabled:
- encryption
- example-theme
- external
- user_external
Are you using encryption: No
Chromium 57.0.2987.98 Built on 8.7, running on Debian 8.8 (64-bit)
Debian Jessie 8.8
Nothing logged.
{"reqId":"eLy2C6A1vJldLlAtVGUy","level":4,"time":"2017-05-19T00:43:34+02:00","remoteAddr":"ip_address","user":"my_user","app":"webdav","method":"PUT","url":"\owncloud\remote.php\webdav\garbage\2017YY0172253.pdf","message":"Exception: {"Message":"An exception occurred while executing 'UPDATE "oc_filecache" SET "mtime" = GREATEST("mtime", ?), "etag" = ? WHERE ("storage" = ?) AND ("path_hash" IN ('d41d8cd98f00b204e9800998ecf8427e', '45b963397aa40d4a0063e0d85e4fe7a1', '092555b67f6aaf450673eefeec1bd065'))' with params ["1495145306.149", "591e2396b822e", 1]:\\n\\nSQLSTATE[22P02]: Invalid text representation: 7 ERROR: invalid input syntax for integer type: "1495145306.149"","Exception":"Doctrine\DBAL\Exception\DriverException","Code":0,"Trace":"#0 \var\www\owncloud\lib\composer\doctrine\dbal\lib\Doctrine\DBAL\DBALException.php(128): Doctrine\DBAL\Driver\AbstractPostgreSQLDriver->convertException('An exception oc...', Object(Doctrine\DBAL\Driver\PDOException))\\n#1 \var\www\owncloud\lib\composer\doctrine\dbal\lib\Doctrine\DBAL\Connection.php(1015): Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOPgSql\Driver), Object(Doctrine\DBAL\Driver\PDOException), 'UPDATE "oc_file...', Array)\\n#2 \var\www\owncloud\lib\private\DB\Connection.php(211): Doctrine\DBAL\Connection->executeUpdate('UPDATE "oc_file...', Array, Array)\\n#3 \var\www\owncloud\lib\composer\doctrine\dbal\lib\Doctrine\DBAL\Query\QueryBuilder.php(208): OC\DB\Connection->executeUpdate('UPDATE `*PREFIX...', Array, Array)\\n#4 \var\www\owncloud\lib\private\DB\QueryBuilder\QueryBuilder.php(141): Doctrine\DBAL\Query\QueryBuilder->execute()\\n#5 \var\www\owncloud\lib\private\Files\Cache\Propagator.php(87): OC\DB\QueryBuilder\QueryBuilder->execute()\\n#6 \var\www\owncloud\lib\private\Files\Cache\HomePropagator.php(48): OC\Files\Cache\Propagator->propagateChange('files\garbage\2...', '1495145306.149', 0)\\n#7 \var\www\owncloud\lib\private\Files\Cache\Updater.php(138): OC\Files\Cache\HomePropagator->propagateChange('files\garbage\2...', '1495145306.149', 0)\\n#8 \var\www\owncloud\lib\private\Files\View.php(314): OC\Files\Cache\Updater->update('files\garbage\2...', '1495145306.149')\\n#9 \var\www\owncloud\lib\private\Files\View.php(1141): OC\Files\View->writeUpdate(Object(OC\Files\Storage\Wrapper\Checksum), 'files\garbage\2...', '1495145306.149')\\n#10 \var\www\owncloud\lib\private\Files\View.php(551): OC\Files\View->basicOperation('touch', '\garbage\2017YY...', Array, '1495145306.149')\\n#11 \var\www\owncloud\apps\dav\lib\Connector\Sabre\File.php(215): OC\Files\View->touch('\garbage\2017YY...', '1495145306.149')\\n#12 \var\www\owncloud\apps\dav\lib\Connector\Sabre\Directory.php(158): OCA\DAV\Connector\Sabre\File->put(Resource id #66)\\n#13 \var\www\owncloud\lib\composer\sabre\dav\lib\DAV\Server.php(1095): OCA\DAV\Connector\Sabre\Directory->createFile('2017YY0172253.p...', Resource id #66)\\n#14 \var\www\owncloud\lib\composer\sabre\dav\lib\DAV\CorePlugin.php(525): Sabre\DAV\Server->createFile('garbage\2017YY0...', Resource id #66, NULL)\\n#15 [internal function]: Sabre\DAV\CorePlugin->httpPut(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\\n#16 \var\www\owncloud\lib\composer\sabre\event\lib\EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#17 \var\www\owncloud\lib\composer\sabre\dav\lib\DAV\Server.php(479): Sabre\Event\EventEmitter->emit('method:PUT', Array)\\n#18 \var\www\owncloud\lib\composer\sabre\dav\lib\DAV\Server.php(254): Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))\\n#19 \var\www\owncloud\apps\dav\appinfo\v1\webdav.php(63): Sabre\DAV\Server->exec()\\n#20 \var\www\owncloud\remote.php(165): require_once('\var\www\own...')\\n#21 {main}","File":"\var\www\owncloud\lib\composer\doctrine\dbal\lib\Doctrine\DBAL\Driver\AbstractPostgreSQLDriver.php","Line":91,"User":"my_user"}"}
jquery-migrate.min.js:2 JQMIGRATE: Migrate is installed, version 1.4.0
js.js:2285 Deprecation warning: tipsy is deprecated. Use tooltip instead.
jQuery.fn.tipsy @ js.js:2285
(anonymous) @ file-upload.js:1011
dispatch @ jquery.min.js:3
r.handle @ jquery.min.js:3
trigger @ jquery.min.js:3
a.event.trigger @ jquery-migrate.min.js:2
(anonymous) @ jquery.min.js:3
each @ jquery.min.js:2
_trigger @ jquery-ui.custom.js:787
_beforeSend @ jquery.fileupload.js:758
(anonymous) @ jquery-ui.custom.js:405
_onSend @ jquery.fileupload.js:869
data.submit @ jquery.fileupload.js:612
(anonymous) @ file-upload.js:260
(anonymous) @ jquery.min.js:2
j @ jquery.min.js:2
add @ jquery.min.js:2
a.Deferred @ jquery-migrate.min.js:2
then @ jquery.min.js:2
submit @ file-upload.js:259
(anonymous) @ file-upload.js:498
_.each._.forEach @ underscore.js:153
submitUploads @ file-upload.js:496
onNoConflicts @ file-upload.js:888
checkExistingFiles @ file-upload.js:700
add @ file-upload.js:906
_trigger @ jquery-ui.custom.js:789
(anonymous) @ jquery.fileupload.js:935
_onAdd @ jquery.fileupload.js:928
(anonymous) @ jquery.fileupload.js:1105
j @ jquery.min.js:2
always @ jquery.min.js:2
_onChange @ jquery.fileupload.js:1099
handlerProxy @ jquery-ui.custom.js:706
start @ file-upload.js:919
j @ jquery.min.js:2
j @ jquery.min.js:2
jquery.min.js:4 PUT https://my_domain/owncloud/remote.php/webdav/garbage/2017YY0172253.pdf 500 (Internal Server Error)
send @ jquery.min.js:4
ajax @ jquery.min.js:4
send @ jquery.fileupload.js:834
(anonymous) @ jquery-migrate.min.js:2
j @ jquery.min.js:2
c.pipe.e.pipe @ jquery-migrate.min.js:2
_onSend @ jquery.fileupload.js:878
j @ jquery.min.js:2
j @ jquery.min.js:2
