Hey everyone. I have managed to get my OC up and running with LDAP authentication and Openstack Swift Object storage. According to this page we should be able to upload larger files. As we will be needing OC for research support, this is a key feature that is needed at our university.
From what I could gather so far, we should be able to upload these large files, but we aren't. The swift documentation as seen here states one needs to enable DLO (Dynamic Large Objects) which we have done. The reasoning behind this is that when you upload a larger object (swift hardcoded a 5GB limit), the client that does the upload needs to be able to chunk the upload. From OC documents it shows that the OC desktop client already does chunking. However, OC seemingly assembles the file again on server side, and to me it seems that this happens befor the upload to Swift Object Store starts, which means we are running into 5GB limit again. Could someone please tell me if I am correct?
1. Install/upgrade to OC 9.1
2. Attach Openstack Swift Object storage as only storage
3. Upload files > 5GB
The file should successfully upload and return success
Owncloud comes back with a message from the swift node stating:
{"reqId":"V6Q4a4bcLdL48RWMAcK6sQAAAAk","remoteAddr":"CLIENT_IP","app":"objectstore","message":"Could not create object: Client error response\n[status code] 413\n[reason phrase] Request Entity Too Large\n[url] https:\/\/swift01.mydomain/\/owncloud2\/urn:oid:2107","level":3,"time":"2016-08-05T08:59:16+02:00","method":"POST","url":"\/index.php\/apps\/files\/ajax\/upload.php"
Note: The url's and IP's has been generified, so please note that they are actually working.
Operating system: CentOS 7
Web server: httpd-2.4.6-40.el7.centos.4.x86_64
Database: mariadb-5.5.47-1.el7_2.x86_64
PHP version: 5.5
ownCloud version: 9.1
Updated from an older ownCloud or fresh install: Updated from 9.0.2
LDAP Authentication
Integrity status for oC9+
Additional info:
I have updated the file limits to 50GB and time-outs to 3600, as stated in OC documentation here
Here is my owncloud config file, I of course removed any privileged info.
<?php
$CONFIG = array (
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
'trusted_domains' =>
array (
0 => 'myserver.example.com',
'datadirectory' => '/var/www/html/owncloud/data',
'overwrite.cli.url' => 'https://myserver.example.com',
'dbtype' => 'mysql',
'version' => '9.1.0.15',
'dbname' => 'owncloud',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'dbuser' => 'owncloud',
'dbpassword' => 'owncloud',
'logtimezone' => 'Africa/Johannesburg',
'installed' => true,
'memcache.local' => '\OC\Memcache\Memcached',
'memcache.distributed' => '\OC\Memcache\Memcached',
'memcached_servers' =>
array (
0 =>
array (
0 => 'localhost',
1 => 11211,
'objectstore' =>
array (
'class' => 'OC\Files\ObjectStore\Swift',
'arguments' =>
array (
'username' => 'owncloud',
'password' => 'owncloudpassword',
'container' => 'containername',
'autocreate' => true,
'region' => 'OurRegion',
'url' => 'http://myswiftserver.example.com/v2.0',
'tenantName' => 'admin',
'serviceName' => 'swift',
'ldapIgnoreNamingRules' => false,
'loglevel' => 0,
'maintenance' => false,
Any help in this regard would be greatly appreciated.
