I would like to know if is planned the release of Linux Distribution Package for Owncloud 10.6.
At the moment I can find only 10.5 packages.
Thank you in advance
Alessandro
Hi Alessandro,
Thanks for letting us know. I’ve forwarded this internally, hopefully we can get this resolved soon.
The Linux packages still don’t seem to be quite correct. An upgrade is not offered - but a new package.
Will this still be changed and/or can we expect official instructions on how to keep our installations up to date?
Thanks in advance from Switzerland!
A package installation will never remove files, therefore upgrading the package will always leave you with a weird version of ownCloud if between versions files have been removed from the tarball.
If you are using the owncloud-files package, I think to upgrade you’d always have to uninstall, remove the old files and install the new package.
But don’t take my word on this process, I don’t use the package out of these reasons (I honestly think it’s a bad idea in general to update a website like that), test what works for you in a test environment (docker container/new vm/clone/whatever works for you).
Make sure you backup data/config/database, you know the drill…
