Hi all,
I just set up owncloud 10.5 and when I’m going to my settings (General), there is no information about the “total” storage.
- Login
- Go to “Settings”
- Click “General”
In an older config, there was the available space on the server and the used space.
No information about the available space is shown
Debian 10
Apache Apache/2.4.38
Maria DB 10.3.23
PHP 7.2.33
ownCloud version:
10.5.0.10
Fresh Install
APT
“system”: {
“updatechecker”: false,
“instanceid”: “ocv69eyy6ub0”,
“trusted_domains”: [
“memcache.local”: “\OC\Memcache\Redis”,
“filelocking.enabled”: true,
“memcache.locking”: “\OC\Memcache\Redis”,
“filelocking.ttl”: 3600,
“redis”: {
“host”: “localhost”,
“port”: 6379,
“timeout”: 0,
“password”: “REMOVED SENSITIVE VALUE”,
“dbindex”: 0
“datadirectory”: “/var/www/owncloud/data”,
“overwrite.cli.url”: “http://REMOVED SENSITIVE VALUE”,
“dbtype”: “mysql”,
“version”: “10.5.0.10”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“logtimezone”: “Europe/Brussels”,
“apps_paths”: [
“path”: “/var/www/owncloud/apps”,
“url”: “/apps”,
“writable”: false
“path”: “/var/www/owncloud/apps-external”,
“url”: “/apps-external”,
“writable”: true
“installed”: true,
“default_language”: “fr”,
“maintenance”: false,
“loglevel”: 2,
“enable_avatars”: false,
“debug”: false,
“trashbin_retention_obligation”: 1
Enabled:
- activity: 2.5.4
- comments: 0.3.0
- configreport: 0.2.0
- dav: 0.6.0
- federatedfilesharing: 0.5.0
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_mediaviewer: 1.0.3
- files_pdfviewer: 0.11.2
- files_sharing: 0.13.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- firstrunwizard: 1.2.0
- gallery: 16.1.1
- market: 0.6.0
- notifications: 0.5.2
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- updatenotification: 0.2.1
**Are you using external storage, if yes which one:
NO
**Are you using encryption:**no
**Are you using an external user-backend, if yes which one: NO
