One of my colleagues has shared a folder with many subfolders containing images, total folder size 16.3 GB. The folder shows when i log in in my internet browser, but does not sync local to my PC (Windows 10).
The folder should sync and appear local on my PC. I have unchecked the box for confirmation when folder exceeds a certain file size, so this should not be a problem.
My other colleagues experience the same problem.
Does anyone have a solution?
ownCloud version:
Client version: 2.5.1
Operating system: Win 10
OS language: English
Installation path of client:
logs.
Client logfile: Output of
owncloud --logwindow
orowncloud --logfile log.txt
(On Windows usingcmd.exe
, you might need to firstcd
into the ownCloud directory)
(See also http://doc.owncloud.org/desktop/2.2/troubleshooting.html#client-logfile ) -
Web server error log:
