On owncloud 8.2.9 with php 7.0.33 , I get the the following log entry, that is messing up my logs as it comes very often.
{“reqId”:“XtZWw9cwGOVtODBDYRlaTAAAAEI”,“remoteAddr”:“xxxxxx”,“app”:“PHP”,“message”:“Function ldap_sort() is deprecated at /var/www/owncloud/apps/user_ldap/lib/ldap.php#264”,“level”:3,
I know that this is a PHP 7.0 warning, but I want to suppress the message at the moment as I’m preparing the server for an upgrade and it makes it hard to use the logs for debugging as most lines contain this error.
At the moment I find no way to suppress this message , even setting the loglevel to log “fatal issues only” does not stop the logging of this error.
Thanks for your help in advance
