Logfile errors for themes directory
  1. Clean install of 16.04 LTS LAMP
  2. Install Owncloud 10.0.3 using webpage owncloud-setup.php
No errors reported in log
Logfile contains errors relating to themes when going into the admin page.
The webpage installer did not create a themes folder, but the logfile reports..
“{“reqId”:“LCJee036VSMOFlv18ohH”,“level”:3,“time”:“2017-10-08T08:55:06+00:00”,“remoteAddr”:“192.168.0.17”,“user”:“admin”,“app”:“PHP”,“method”:“GET”,“url”:”/owncloud/index.php/settings/admin?sectionid=general",“message”:“opendir(/var/www/html/owncloud/themes): failed to open dir: No such file or directory at /var/www/html/owncloud/apps/templateeditor/lib/mailtemplate.php#155”}"
Creating an empty themes directory as a workaround stopper the error messages.
Operating system: Ubuntu 16.04 LTS
Web server: Apache
Database: MYSQL
PHP version: 7.0
ownCloud version: (see ownCloud admin page) 10.0.3
Updated from an older ownCloud or fresh install: Fresh
Where did you install ownCloud from: https://download.owncloud.com/download/community/setup-owncloud.php
I think you should report this directly to the bugtracker.
