1.nano /var/www/html/config/config.php
‘log_type’ => ‘owncloud’,
‘logfile’ => ‘/var/log/owncloud.log’,
‘loglevel’ => 2,
‘log_rotate_size’ => 104857600,
2.[root@cos-01 config]# chmod 644 /var/log/owncloud.log
[root@cos-01 config]# ls -alh /var/log/owncloud.log
-rw-r–r-- 1 apache apache 92K Aug 10 08:42 /var/log/owncloud.log
3.login as admin
tail -f /var/log/owncloud.log
{“reqId”:“W2zr5vwKo1FSBB0xD@XxQAAAAAk”,“level”:3,“time”:“2018-08-10T09:35:35+08:00”,“remoteAddr”:"******",“user”:"–",“app”:“no app in context”,“method”:“POST”,“url”:"/index.php/login",“message”:“User backend OC\User\Database is returning home: /home/ocdata//admin for user: admin which differs from existing value: /var/www/html/data/admin”}
[root@cos-01 conf.d]# ls -alh /var/log/owncloud.log
-rw-r----- 1 apache apache 92K Aug 10 09:35 /var/log/owncloud.log
the privilege of the log file auto restore to 640,and the same if put the log file under ocdata folder
for this situation , my zabbix can’t access the log file of owncloud because the user zabbix has no permission to the log file, even adding group apache to user zabbix , the zabbix program shows no persmission to the file
Operating system:CentOS Linux release 7.5.1804 (Core)
Web server: Apache
**Database:**MariaDB
PHP version: php 7
ownCloud version: (see ownCloud admin page) ownCloud 10.0.9
Updated from an older ownCloud or fresh install: updated from an older owncloud
Where did you install ownCloud from: owncloud.com
Signing status (ownCloud 9.0 and above): sorry for my poor english,what does this mean?
