- Start Owncloud server;
- Enter URL into browser (using Chrome);
- Execute attempted login.
Successful login into my account.
I had no difficulty logging in earlier after I initially installed Owncloud. Note: I’m using VMWare workstation as host. The trouble began after I installed a few applications, actually 4 in total, and a few plugins/extensions. In addition, the desktop client has never
worked for me in login attempts. The area where the url is has turned bright red.
Windows 10 64 bit
Using VMWare Workstation 12
Virtualized
Virtualized
10 (latest)
No, fresh installation.
The official website, nothing third-party.
Administrator
Don’t remember exactly, but they were typical for file transfers with client accessibility. Also, tried the command line to get a listing of the applications. Response was “failure to open”.
N/A
No.
No.
SELECT * FROM oc_appconfig WHERE appid = ‘user_ldap’;
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
c) …
Finally, this isn't a matter of grave importance. I'm using ownCloud for personal projects. I also haven't lost any data, I'm just not able to login to my account.
Christopher
