my Owncloud client often freezes for quite a while and a quick look into the output of strace
shows me that it is reading and writing lots of things from and to the sqlite database located in $localPath/$journalPath
like there are configured in ~/.config/ownCloud/owncloud.cfg
Because my localPath
is a RAID5 HDD Array and random access are not as fast as it would be on a SSD drive, I wonder if I can change the journalPath
to my SSD after moving the ._sync_abc.db
file to the new location. This way I hope to get a better performance while the client is working on the database.
Also I am wondering why the .db-wal
file is more than double the size of the .db
file. Is that normal behavior? Shouldn’t that .db-wal
file be merged with the .db
and emptied in regular time intervals?
At the moment I have running version 2.6.3 (build 2668) and it says there are now updates available.
