I am getting a “Multiple accounts are sharing the folder…”
when I don’t have multiple accounts.
I do have multiple devices but only one account but the folder this error is shown on is only on one device with one user.
What do I do?
What do I do?
To tell you the truth I did read the answer but as I don’t know any SQL I don’t know what to do or how to do it. I need a little more help as to: Where are the files it is talking about, “Desktop sync client discovered multiple sync journals (SQLite database files) in the folder.” Where is this folder or how do I find it? How do I delete a “sync journal” from a SQLite database?
Update. I found some .sync… files but they seem not to be part of a SQL database as there in the folder I was syncing to my owncloud sever. I have not checked the SQL server as I don’t know how to but deleting the .sync… files seemed to work.
Was that the right thing to do?
