I’ve set up OC according to docs provided. All features works perfectly except one - https://cloud.naïve.io/ is not handled properly and displays ‘file not found’. Any other pages (https://cloud.naïve.io/*) works.
OS: Ubuntu 16.04
Proxy Server: NGINX
PHP: v7.0
DB: MariaDB
NGINX config file configured according to provided example:
upstream php-handler {
server unix:/run/php/php7.0-fpm.sock;
server {
listen 80;
server_name cloud.xn--nave-6pa.io;
return 301 https://$server_name$request_uri;
server {
listen 443 ssl http2;
ssl_certificate #;
ssl_certificate_key #;
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains";
add_header X-Content-Type-Options nosniff;
add_header X-Frame-Options "SAMEORIGIN";
add_header X-XSS-Protection "1; mode=block";
add_header X-Robots-Tag none;
add_header X-Download-Options noopen;
add_header X-Permitted-Cross-Domain-Policies none;
root /var/www/owncloud/;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
location = /.well-known/carddav {
return 301 $scheme://$host/remote.php/dav;
location = /.well-known/caldav {
location /.well-known/acme-challenge { }
fastcgi_buffers 64 4K;
gzip off;
error_page 403 /core/templates/403.php;
error_page 404 /core/templates/404.php;
location / {
rewrite ^ /index.php$uri;
location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)/ {
return 404;
location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console) {
return 404;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
fastcgi_split_path_info ^(.+\.php)(/.*)$;
include fastcgi_params;
include snippets/fastcgi-php.conf;
fastcgi_param PATH_INFO $fastcgi_path_info;
fastcgi_param HTTPS on;
fastcgi_param modHeadersAvailable true;
fastcgi_param front_controller_active true;
fastcgi_pass unix:/run/php/php7.0-fpm.sock;
fastcgi_intercept_errors on;
fastcgi_request_buffering off;
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri $uri/ =404;
index index.php;
location ~* \.(?:css|js)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control "public, max-age=7200";
#add_header Strict-Transport-Security "max-age=15552000; includeSubDomains";
access_log off;
location ~* \.(?:svg|gif|png|html|ttf|woff|ico|jpg|jpeg)$ {
access_log off;
