No password reset possible after deactivating server side encryption
  1. Enable Server Encryption
  2. Create Users, upload files
  3. Disable Server Encryption
  4. Login and Logout with user A
  5. Try to reset the password for user A (forget password mechanism)
  6. Passwort reset Link is sent
  7. Enter new Password, press button.
Password is reset after entering a new password.
Message: “Private Key missing for user: please try to log-out and log-in again”
The json response from the server has a http code of 200 and a content of
{"status":"error","msg":"Private Key missing for user: please try to log-out and log-in again"}
Despite this message, the password is actually reset. So you can login with this new password, but you can not access the files, that have been decrypted in the past. When logged in I alway the the message “Invalid private key for Encryption App. Please update your private key password in your personal settings to recover access to your encrypted files”. As the user that resets his password does not know his old one, these files are lost?
Operating system: CentOS 7
Web server: Apache
Database: Maria db
PHP version: PHP 5.5.38
ownCloud version (see ownCloud admin page): 9.1.3
Updated from an older ownCloud or fresh install: update from 9.1.1
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): previously enabled Server side encryption
Exception: {"Exception":"OCA\\Encryption\\Exceptions\\PrivateKeyMissingException","Message":"Private Key missing for user: please try to log-out and log-in again","Code":0,"Trace":"#0 \/var\/www\/html\/owncloud\/apps\/encryption\/lib\/Hooks\/UserHooks.php(230): OCA\\Encryption\\Session->getPrivateKey()\n#1 [internal function]: OCA\\Encryption\\Hooks\\UserHooks->setPassphrase(Array)\n#2 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/hook.php(105): call_user_func(Array, Array)\n#3 \/var\/www\/html\/owncloud\/lib\/private\/Server.php(261): OC_Hook::emit('OC_User', 'post_setPasswor...', Array)\n#4 [internal function]: OC\\Server->OC\\{closure}(Object(OC\\User\\User), 'Yamsmos#0816', NULL)\n#5 \/var\/www\/html\/owncloud\/lib\/private\/Hooks\/EmitterTrait.php(98): call_user_func_array(Object(Closure), Array)\n#6 \/var\/www\/html\/owncloud\/lib\/private\/Hooks\/PublicEmitter.php(32): OC\\Hooks\\BasicEmitter->emit('\\\\OC\\\\User', 'postSetPassword', Array)\n#7 \/var\/www\/html\/owncloud\/lib\/private\/User\/User.php(236): OC\\Hooks\\PublicEmitter->emit('\\\\OC\\\\User', 'postSetPassword', Array)\n#8 \/var\/www\/html\/owncloud\/core\/Controller\/LostController.php(219): OC\\User\\User->setPassword('Yamsmos#0816')\n#9 [internal function]: OC\\Core\\Controller\\LostController->setPassword('VbaWND4zn9LXAwu...', 'lilli.heyer@war...', 'Yamsmos#0816', false)\n#10 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(159): call_user_func_array(Array, Array)\n#11 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(89): OC\\AppFramework\\Http\\Dispatcher->executeController(Object(OC\\Core\\Controller\\LostController), 'setPassword')\n#12 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/App.php(110): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OC\\Core\\Controller\\LostController), 'setPassword')\n#13 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/Routing\/RouteActionHandler.php(46): OC\\AppFramework\\App::main('LostController', 'setPassword', Object(OC\\AppFramework\\DependencyInjection\\DIContainer), Array)\n#14 [internal function]: OC\\AppFramework\\Routing\\RouteActionHandler->__invoke(Array)\n#15 \/var\/www\/html\/owncloud\/lib\/private\/Route\/Router.php(280): call_user_func(Object(OC\\AppFramework\\Routing\\RouteActionHandler), Array)\n#16 \/var\/www\/html\/owncloud\/lib\/base.php(891): OC\\Route\\Router->match('\/lostpassword\/s...')\n#17 \/var\/www\/html\/owncloud\/index.php(39): OC::handleRequest()\n#18 {main}","File":"\/var\/www\/html\/owncloud\/apps\/encryption\/lib\/Session.php","Line":78}
Integrity status for oC9+
from the issue template you have filled out:
Before posting please snip make sure that you’re running the latest available version for your oC release: Changelog - ownCloud
In this case the current version is 9.1.3. It might also worth to test the RC of the upcoming 9.1.4 which shows some additional fixes to encryption:
Thanks for your reply.
Although I did not found any hints for bugfixes in the encryption in the release notes between 9.1.1 and 9.1.3, I updated my installation. But the error remains the same.
As i have over 20 users on my owncloud installation, it would be nice if we find a solution for that.
Now I deleted the files_encryption folder for a testuser, and the massage
does not appear after a password reset.
If we could find out why the message
appears when pressing “reset password” we could mitigate this problem.
Are there any database preferences that could be changed? I did not fond anything helpful when searching in the db.
See:
If that doesn’t fix your issue report a new issue at GitHub · Where software is built
Reports of such issues in here won’t get noticed and are lost in the void.
I found the Problem: The encryption plugin was still activated, although the encryption was deactivated. Deactivating the plugin solved my Problems.
