Hallo
I’m new here. Sorry for my bad english.
I have run owncloud 10.0.6 on a Raspberry (Stretch). I would update to 10.0.7.
If I press the update button, I get the following error:
"cURL error 60: SSL certificate problem: self signed certificate "
Where is the problem?
Hallo I could not solve the problem yet. I switched to the directory / var / www / cloud When I enter "occ maintenance: mode --off", I get the following message: "Command not found". I have owncloud installed in the path / var / www / cloud. The default path is / var / www / owncloud. In which file do I have to adjust the path to find the command?
