1.Switch mobile phone to only using cellular data
2.upload files bigger than ~700kb
Upload of files bigger than 700KB.
Nothing happens, no error occures and no log entrie is created.
Same behaviour if I use the smartphone as a hotspot and try to Upload from a laptop.
If a wireless network is used, no problems occure, I can upload for example 4GB of backups.
Operating system: Red Hat enterprise linux 7.9
Web server: httpd-2.4.6-97.el7_9.x86_64
Database: 5.5.68-MariaDB
PHP version: php-7.2.34-3.el7.remi.x86_64
ownCloud version: 10.6.0.5
**Where did you install ownCloud from: ownCloud Repository
Enabled:
- activity: 2.6.0
- comments: 0.3.0
- configreport: 0.2.0
- dav: 0.6.0
- diagnostics: 0.1.4
- encryption: 1.4.0
- federatedfilesharing: 0.5.0
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_mediaviewer: 1.0.4
- files_pdfviewer: 0.12.1
- files_sharing: 0.14.0
- files_texteditor: 2.3.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- market: 0.6.0
- mynewtheme: 1.0.0
- notifications: 0.5.2
- password_policy: 2.1.2
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.4.0
- twofactor_backup_codes: 0.1.0
- updatenotification: 0.2.1
**Are you using external storage, if yes which one: no
Are you using encryption: yes
Browser: Chrome/Edge
Operating system: Android, Windows
No error added
No error added
