The client on the RaspberryPi should download (sync) all the data from OwnCloud server. (also on the RaspberryPi)
The client on the RaspberryPi syncs all the data from OwnCloud server (all files are available on the client), but then throws an error: “Not allowed to remove, restoring; Restoration Failed: Permission denied” (just appears for big files >2GB I guess) I don’t know why the client wants to remove files, but after I come across this the first time, I created a second user which just have read-rights, so no data gets lost.
- Load big files on an ownCloud server
- Try to sync them on a RaspberryPi
- Error appears
Operating system: Raspbian Buster
Web server: Apache 2
Database: sql
PHP version: 7.3
ownCloud version: 10.4.1
Client version: 2.5.1
OS language: Englisch US (UTF-8)
That’s how I installed the client:
echo ‘deb http://download.opensuse.org/repositories/isv:/ownCloud:/desktop/Debian_10/ /’ > /etc/apt/sources.list.d/isv:ownCloud:desktop.list
wget -nv https://download.opensuse.org/repositories/isv:ownCloud:desktop/Debian_10/Release.key -O Release.key
sudo apt-key add - < Release.key
sudo apt-get update
sudo apt-get install owncloud-client
I changed the following in php.ini:
- upload_tmp_dir = /media/nas-drive-server/temp
- upload_max_filesize = 50G
- post_max_filesize = 50G
Do you need some other logs?
