1.Download file > 1GB stopping at 1GB
2. htaccess and user.ini has limits raised
3.
Download file greater then 1GB should download fully.
Download stops and says completed…file only 1GB
AlmaLinux v8.6.0 STANDARD vzcontainer
cPanel
MSQL
10.0.11
