I’m updating owncloud from 10.7.0 to 10.8.0.
PHP 7.4.22
Apache 2.4
Centos 7.4
Seem an error of connection, but if I put old owncloud folder then it’ll work fine, so the DB configuration work fine.
I copy from owncloud_old/config/ to owncloud/config
I get this error:
[root@localhost owncloud]# sudo -u data-www php occ upgrade
2021-08-03T13:58:31+00:00 Set log level to debug
2021-08-03T13:58:31+00:00 Repair step: Upgrade app code from the marketplace
2021-08-03T13:58:31+00:00 Repair step: Repair MySQL database engine
2021-08-03T13:58:31+00:00 Repair step: Repair MySQL collation
2021-08-03T13:58:31+00:00 Repair info: All tables already have the correct collation → nothing to do
2021-08-03T13:58:31+00:00 Repair step: Repair SQLite autoincrement
2021-08-03T13:58:31+00:00 Repair step: Repair orphaned reshare
2021-08-03T13:58:31+00:00 Repair step: Repair duplicate entries in oc_lucene_status
Error: Call to undefined method OC\DB\Connection::fetchAllAssociative() in /var/www/html/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Schema/AbstractSchemaManager.php:225
Stack trace:
#0 /var/www/html/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Schema/AbstractSchemaManager.php(213): Doctrine\DBAL\Schema\AbstractSchemaManager->listTableNames()
#1 /var/www/html/owncloud/lib/private/DB/Connection.php(383): Doctrine\DBAL\Schema\AbstractSchemaManager->tablesExist(Array)
#2 /var/www/html/owncloud/lib/private/Repair/SearchLuceneTables.php(57): OC\DB\Connection->tableExists(‘oc_lucene_statu…’)
#3 /var/www/html/owncloud/lib/private/Repair.php(90): OC\Repair\SearchLuceneTables->run(Object(OC\Repair))
#4 /var/www/html/owncloud/lib/private/Updater.php(261): OC\Repair->run()
#5 /var/www/html/owncloud/lib/private/Updater.php(114): OC\Updater->doUpgrade(‘10.7.0.4’, ‘10.7.0.4’)
#6 /var/www/html/owncloud/core/Command/Upgrade.php(266): OC\Updater->upgrade()
#7 /var/www/html/owncloud/lib/composer/symfony/console/Command/Command.php(255): OC\Core\Command\Upgrade->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#8 /var/www/html/owncloud/lib/composer/symfony/console/Application.php(1009): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#9 /var/www/html/owncloud/lib/composer/symfony/console/Application.php(273): Symfony\Component\Console\Application->doRunCommand(Object(OC\Core\Command\Upgrade), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#10 /var/www/html/owncloud/lib/composer/symfony/console/Application.php(149): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#11 /var/www/html/owncloud/lib/private/Console/Application.php(165): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#12 /var/www/html/owncloud/console.php(116): OC\Console\Application->run()
#13 /var/www/html/owncloud/occ(11): require_once(’/var/www/html/o…’)
what can it be?
Where do owncloud store the password (other config.php)?
I add, the password in config.php is in clear, like old version of owncloud, How can I encrypt the password for the new version?
thanks
