I am using owncloud 10.2.1
Onlyoffice 5.4.2.46.
Everything was working well, but my wildcard SSL cert expired.
After I replace it for a new one, I can’t get onlyoffice to work again.
I do have this error each time I try to apply the setting :
Error when trying to connect (cURL error 60: SSL certificate problem: unable to get local issuer certificate)
My cert are outside the container is a dedicated volume:
-v onlyoffice-cert:/var/www/onlyoffice/Data \
I check about 20 times that onlyoffice.cert and onlyoffice.key where the right one.
Anyone have a clue?
R,
