Won't load.
Tried to re-run with 16.04 but no luck...
Ran purge, then re-installed... still no-go.
Any tips on how to clean this up would be appreciated.
Thanks,
Chris.
Won't load.
Thanks,
Chris.
You can start the client from terminal and activate logging:
https://doc.owncloud.org/desktop/2.2/troubleshooting.html#saving-files-directly
I get this:
Segmentation fault (core dumped)
Then open a ticket on the bugtracker:
