I have added below lines to config.php but on IDP logs is just “GET /oauth/authorize?/.well-known/openid-configuration”
‘openid-connect’ =>
array (
‘provider-url’ => ‘https://example.com/login’,
‘scope’ => ‘openid’,
‘response_type’ => ‘code’,
‘client-id’ => ‘login_id’,
‘client-secret’ => ‘password’,
‘autoRedirectOnLoginPage’ => false,
‘mode’ => ‘userid’,
I have tried other options too.
