I’ve migrated from a bare-metal installation with Apache, ownCloud and MySQL to a Kubernetes deployment, based on the docker-compose.yml
. The web interface seems fine but when doing a sync which includes a large number of files, the client eventually fails with Server replied with an error while reading directory '/path/goes/here' : Operation canceled
- Install fresh ownCloud installation in Docker/Kubernetes, based on
- Add existing user data
- Run
occ files:scan
to rebuild the database
Sync should occur normally
Small syncs (approx 100GB of data) complete OK. Large syncs (approx 900GB of data) fail during Checking for changes in remote
with error Server replied with an error while reading directory '/path/goes/here' : Operation canceled
Database health appears fine, never runs out of available connections or reports an error
Operating system: Fedora 31 running ownCloud Docker image 10.3.2
[jonathan@zeus ~]$ kubectl exec -it owncloud-68c4cbb6b6-b9484 -- apache2 -v
Server version: Apache/2.4.41 (Ubuntu)
Server built: 2019-08-14T14:36:32
[jonathan@zeus ~]$ kubectl exec -it mysql-869b967588-tctpq -- mysql -V
mysql Ver 15.1 Distrib 10.4.8-MariaDB, for Linux (x86_64) using readline 5.1
[jonathan@zeus ~]$ kubectl exec -it owncloud-68c4cbb6b6-b9484 -- php -v
PHP 7.3.11-0ubuntu0.19.10.1 (cli) (built: Oct 24 2019 11:38:49) ( NTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.3.11, Copyright (c) 1998-2018 Zend Technologies
with Zend OPcache v7.3.11-0ubuntu0.19.10.1, Copyright (c) 1999-2018, by Zend Technologies
10.3.2
Fresh install with user data imported
Docker Hub
[jonathan@zeus ~]$ kubectl exec -it owncloud-68c4cbb6b6-b9484 -- occ app:list
Enabled:
- comments: 0.3.0
- configreport: 0.2.0
- dav: 0.5.0
- federatedfilesharing: 0.5.0
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_mediaviewer: 1.0.1
- files_sharing: 0.12.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- firstrunwizard: 1.2.0
- market: 0.5.0
- notifications: 0.5.0
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- updatenotification: 0.2.1
Disabled:
- encryption
- external
- user_external
- user_ldap
Are you using external storage, if yes which one:
Kubernetes persistent volume, mounted as local storage
[jonathan@zeus ~]$ kubectl describe pvc files
Namespace: owncloud
StorageClass: microk8s-hostpath
Status: Bound
Volume: pvc-f7f21d80-2e7c-4539-8496-d211b92342a6
Labels: service=files
Annotations: control-plane.alpha.kubernetes.io/leader:
{"holderIdentity":"626cfbb7-4447-11ea-906b-eebe1ec7b0d9","leaseDurationSeconds":15,"acquireTime":"2020-01-31T17:28:01Z","renewTime":"2020-...
kubectl.kubernetes.io/last-applied-configuration:
{"apiVersion":"v1","kind":"PersistentVolumeClaim","metadata":{"annotations":{},"labels":{"service":"files"},"name":"files","namespace":"ow...
pv.kubernetes.io/bind-completed: yes
pv.kubernetes.io/bound-by-controller: yes
volume.beta.kubernetes.io/storage-provisioner: microk8s.io/hostpath
Finalizers: [kubernetes.io/pvc-protection]
Capacity: 2560Gi
Access Modes: RWO
VolumeMode: Filesystem
Mounted By: owncloud-68c4cbb6b6-b9484
Events: <none>
No
No
Browser: ownCloud desktop client on Linux v2.6.0
[jonathan@zeus ~]$ kubectl logs owncloud-68c4cbb6b6-b9484
Creating volume folders...
Creating hook folders...
Waiting for MySQL...
services are ready!
Waiting for Redis...
services are ready!
Removing custom folder...
Linking custom folder...
Removing config folder...
Linking config folder...
Writing config file...
Fixing base perms...
Fixing data perms...
Fixing hook perms...
Upgrading server database...
ownCloud is already latest version
Writing objectstore config...
Writing php config...
Updating htaccess config...
.htaccess has been updated
Writing apache config...
Enabling cron background...
Set mode for background jobs to 'cron'
Touching cron configs...
Starting cron daemon...
Starting apache daemon...
[Mon Feb 03 11:46:12.298522 2020] [mpm_prefork:notice] [pid 192] AH00163: Apache/2.4.41 (Ubuntu) configured -- resuming normal operations
[Mon Feb 03 11:46:12.298572 2020] [core:notice] [pid 192] AH00094: Command line: '/usr/sbin/apache2 -f /etc/apache2/apache2.conf -D FOREGROUND'
{"reqId":"723ff548293e4d23c6ed3d16c110c24f","level":3,"time":"2020-02-03T11:46:16+00:00","remoteAddr":"10.1.40.1","user":"jonathan","app":"PHP","method":"GET","url":"\/remote.php\/dav\/files\/jonathan\/Local\/Arthur%20phonecall%202018-04-20.mp3?c=163ccf703c69e922acc31476e4a6e551&x=32&y=32&forceIcon=0&preview=1","message":"imagecreatefromstring(): Empty string or invalid image at \/var\/www\/owncloud\/lib\/private\/legacy\/image.php#573"}
03/02/2020 12:12:05, , ownCloud,Server replied with an error while reading directory 'Documents/School/Computing/Oct Halfterm 2003' : Operation canceled
