- Fresh install Owncloud 10.0.2 on Debian 9
- Setup Nginx as reverse proxy for Owncloud
Normal Owncloud behaviour
When I login as admin I get this warning
This directory is unavailable, please check the logs or contact the administrator
Error on the admin page
Your web server is not yet set up properly to allow file synchronization because the WebDAV interface seems to be broken.
Operating system: Debian 9
Web server: Apache 2.4.25
**Database:**Mariadb 10.1.23-9+deb9u1
**PHP version:**PHP 7.0.19-1
ownCloud version: (see ownCloud admin page) 10.0.2 (stable)
Where did you install ownCloud from: download.owncloud.com
“system”: {
“instanceid”: “ocveunqme074”,
“trusted_domains”: [
“domain.com”,
"Public IP,
“datadirectory”: “REMOVED SENSITIVE VALUE”,
“overwrite.cli.url”: “https://domain.com/owncloud”,
“dbtype”: “mysql”,
“version”: “10.0.2.1”,
“dbname”: “cloud”,
“dbhost”: “127.0.0.1”,
“dbtableprefix”: “oc_”,
“logtimezone”: “UTC”,
“installed”: true,
“forwarded_for_headers”: [
“HTTP_X_FORWARDED_FOR”
“loglevel”: “0”,
“overwritehost”: “domain.com”,
“overwriteprotocol”: “https”,
“overwritewebroot”: “/owncloud”
Enabled:
- configreport: 0.1.1
- dav: 0.2.9
- federatedfilesharing: 0.3.0
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.0
- files_sharing: 0.10.0
- files_trashbin: 0.9.0
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- gallery: 16.0.2
- notifications: 0.3.0
- templateeditor: 0.1
- updatenotification: 0.2.1
Disabled: - comments
- encryption
- external
- files_antivirus
- firstrunwizard
- market
- provisioning_api
- systemtags
- theme-example
- user_external
Are you using encryption: no
**Are you using an external user-backend, if yes which one: no
Browser: Chromium
Operating system: Kali linux
{"reqId":"ypOwIkvFjsfOYaZHxYCg","level":4,"time":"2017-08-03T21:23:00+00:00","remoteAddr":"xxx.xxx.xxx.xxx","user":"user","app":"webdav","method":"PROPFIND","url":"\/owncloud\/\/remote.php\/webdav\/","message":"Exception: {\"Message\":\"Requested uri (\\\/owncloud\\\/\\\/remote.php\\\/webdav\\\/) is out of base uri (\\\/owncloud\\\/\\\/remote.php\\\/webdav\\\/)\",\"Exception\":\"LogicException\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1295): Sabre\\\\HTTP\\\\Request->getPath()\\n#1 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(474): Sabre\\\\DAV\\\\Server->checkPreconditions(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(63): Sabre\\\\DAV\\\\Server->exec()\\n#4 \\\/var\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/var\\\/www\\\/ownclo...')\\n#5 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/http\\\/lib\\\/Request.php\",\"Line\":214,\"User\":\"user\"}"}
Hello all,
I hope I can get help here.
My issue is very similar to this one:
ownCloud Central and I already try the 2 links from this topic but they didn’t work for me.
Any other ideas ?
Maybe I just missed something in my Nginx conf …
location /owncloud {
proxy_pass http://domain.com/owncloud;
Thank’s.
