- Try to login as admin
Normal operation
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Owncloud log:
{“reqId”:“8qhsjIv7DqAi50T4xtgv”,“level”:3,“time”:“2019-03-12T12:35:01+00:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"–",“url”:"–",“message”:“Redis::connect(): connect() failed: php_network_getaddresses: getaddrinfo failed: Name or service not known at /var/www/html/owncloud/lib/private/RedisFactory.php#81”}
CentOS 7 minimal install
Checked:
SELinux audit log
Redis log
Apache log
Found no issues (Owncloud is ok without Redis config)
Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/7.2.16 configured
MySQL
10.1.0.4
fresh install
packages ( http://download.owncloud.org/download/repositories/production/CentOS_7/ce:stable.repo)
Unable to access
<?php $CONFIG = array ( 'updatechecker' => false, 'instanceid' => 'oc5k0jvh6bst', 'passwordsalt' => 'sensitiveValue', 'secret' => 'sensitiveValue', 'trusted_domains' => array ( 0 => 'sensitiveValue', ), 'memcache.local' => '\\OC\\Memcache\\Redis', //tried \OC\Memcache\Redis 'filelocking.enabled' => 'true', 'memcache.distributed' => '\\OC\\Memcache\\Redis', 'memcache.locking' => '\\OC\\Memcache\\Redis', 'redis' => array ( 'host' => '\/tmp\/redis.sock', //tried /tmp/redis.sock 'port' => 0, 'timeout' => 0, 'dbindex' => 0, ), 'datadirectory' => '/var/www/html/owncloud/data', 'overwrite.cli.url' => 'http://sensitiveValue/owncloud', 'dbtype' => 'mysql', 'version' => '10.1.0.4', 'dbname' => 'sensitiveValue', 'dbhost' => 'localhost', 'dbtableprefix' => 'sensitiveValue', 'dbuser' => 'sensitiveValue', 'dbpassword' => 'sensitiveValue', 'logtimezone' => 'UTC', 'installed' => true, ); ``` Log in to the web-UI with an administrator account and click on 'admin' -> 'Generate Config Report' -> 'Download ownCloud config report' This report includes the config.php settings, the list of activated apps and other details in a well sanitized form. or If you have access to your command line run e.g.: sudo -u www-data php occ config:list system from within your ownCloud installation folder *ATTENTION:* Do not post your config.php file in public as is. Please use one of the above methods whenever possible. Both, the generated reports from the web-ui and from occ config:list consistently remove sensitive data. You still may want to review the report before sending. If done manually then it is critical for your own privacy to dilligently remove *all* host names, passwords, usernames, salts and other credentials before posting. You should assume that attackers find such information and will use them against your systems. ``` **List of activated apps:** ``` If you have access to your command line run e.g.: sudo -u www-data php occ app:list from within your ownCloud installation folder. ``` **Are you using external storage, if yes which one:** local/smb/sftp/... No **Are you using encryption:** yes/no no **Are you using an external user-backend, if yes which one:** LDAP/ActiveDirectory/Webdav/... no #### LDAP configuration (delete this part if not used) ``` With access to your command line run e.g.: sudo -u www-data php occ ldap:show-config from within your ownCloud installation folder Without access to your command line download the data/owncloud.db to your local computer or access your SQL server remotely and run the select query: SELECT * FROM `oc_appconfig` WHERE `appid` = 'user_ldap'; Eventually replace sensitive data as the name/IP-address of your LDAP server or groups. ``` ### Client configuration **Browser:** Chrome **Operating system:** Windows 10 ### Logs #### Web server error log ``` Insert your webserver log here ``` [Tue Mar 12 13:24:32.418359 2019] [mpm_prefork:notice] [pid 26098] AH00170: caught SIGWINCH, shutting down gracefully [Tue Mar 12 13:24:33.532040 2019] [core:notice] [pid 26207] SELinux policy enabled; httpd running as context system_u:system_r:httpd_t:s0 [Tue Mar 12 13:24:33.533076 2019] [suexec:notice] [pid 26207] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec) [Tue Mar 12 13:24:33.573588 2019] [auth_digest:notice] [pid 26207] AH01757: generating secret for digest authentication ... [Tue Mar 12 13:24:33.574472 2019] [lbmethod_heartbeat:notice] [pid 26207] AH02282: No slotmem from mod_heartmonitor [Tue Mar 12 13:24:33.622167 2019] [mpm_prefork:notice] [pid 26207] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/7.2.16 configured -- resuming normal operations [Tue Mar 12 13:24:33.622248 2019] [core:notice] [pid 26207] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND' [Tue Mar 12 13:24:47.397276 2019] [autoindex:error] [pid 26208] [client sensitiveValue:55627] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:25:17.393663 2019] [autoindex:error] [pid 26212] [client sensitiveValue:55728] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:25:47.392327 2019] [autoindex:error] [pid 26210] [client sensitiveValue:55830] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:26:17.392659 2019] [autoindex:error] [pid 26209] [client sensitiveValue:55931] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:26:47.391586 2019] [autoindex:error] [pid 26211] [client sensitiveValue:56037] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:27:17.392521 2019] [autoindex:error] [pid 26208] [client sensitiveValue:56138] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:27:47.392062 2019] [autoindex:error] [pid 26212] [client sensitiveValue:56242] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:28:17.393236 2019] [autoindex:error] [pid 26210] [client sensitiveValue:56348] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:28:47.389543 2019] [autoindex:error] [pid 26209] [client sensitiveValue:56454] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:29:17.391580 2019] [autoindex:error] [pid 26211] [client sensitiveValue:56557] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:29:47.392733 2019] [autoindex:error] [pid 26208] [client sensitiveValue:56659] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:30:17.392548 2019] [autoindex:error] [pid 26212] [client sensitiveValue:56761] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:30:47.392462 2019] [autoindex:error] [pid 26210] [client sensitiveValue:56864] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:31:17.391820 2019] [autoindex:error] [pid 26209] [client sensitiveValue:56965] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:31:47.391403 2019] [autoindex:error] [pid 26211] [client sensitiveValue:57068] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:32:17.388764 2019] [autoindex:error] [pid 26208] [client sensitiveValue:57173] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:32:47.388415 2019] [autoindex:error] [pid 26212] [client sensitiveValue:57346] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:33:17.388177 2019] [autoindex:error] [pid 26210] [client sensitiveValue:57448] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:33:47.389350 2019] [autoindex:error] [pid 26209] [client sensitiveValue:57550] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:34:17.387041 2019] [autoindex:error] [pid 26211] [client sensitiveValue:57653] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:34:47.394580 2019] [autoindex:error] [pid 26208] [client sensitiveValue:57754] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:35:17.389421 2019] [autoindex:error] [pid 26212] [client sensitiveValue:57856] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:35:47.388939 2019] [autoindex:error] [pid 26210] [client sensitiveValue:57958] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:36:17.385792 2019] [autoindex:error] [pid 26209] [client sensitiveValue:58059] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:36:47.389151 2019] [autoindex:error] [pid 26211] [client sensitiveValue:58162] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:37:20.526918 2019] [autoindex:error] [pid 26208] [client sensitiveValue:58263] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:37:47.387631 2019] [autoindex:error] [pid 26212] [client sensitiveValue:58366] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:38:17.386375 2019] [autoindex:error] [pid 26210] [client sensitiveValue:58474] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:38:47.386194 2019] [autoindex:error] [pid 26209] [client sensitiveValue:58576] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:39:17.384100 2019] [autoindex:error] [pid 26211] [client sensitiveValue:58679] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:39:47.418984 2019] [autoindex:error] [pid 26208] [client sensitiveValue:58784] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:40:17.419364 2019] [autoindex:error] [pid 26212] [client sensitiveValue:58885] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:40:47.384112 2019] [autoindex:error] [pid 26210] [client sensitiveValue:58986] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:41:17.384359 2019] [autoindex:error] [pid 26209] [client sensitiveValue:59090] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:41:47.384694 2019] [autoindex:error] [pid 26211] [client sensitiveValue:59192] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:42:17.382026 2019] [autoindex:error] [pid 26208] [client sensitiveValue:59294] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:42:47.381945 2019] [autoindex:error] [pid 26212] [client sensitiveValue:59396] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:43:17.384700 2019] [autoindex:error] [pid 26210] [client sensitiveValue:59497] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:43:47.382715 2019] [autoindex:error] [pid 26209] [client sensitiveValue:59600] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:44:17.383723 2019] [autoindex:error] [pid 26211] [client sensitiveValue:59701] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:44:47.381245 2019] [autoindex:error] [pid 26208] [client sensitiveValue:59807] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:45:17.381278 2019] [autoindex:error] [pid 26212] [client sensitiveValue:59914] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive [Tue Mar 12 13:45:47.382185 2019] [autoindex:error] [pid 26210] [client sensitiveValue:60016] AH01276: Cannot serve directory /var/www/html/: No matching DirectoryIndex (index.html,index.php) found, and server-generated directory index forbidden by Options directive #### ownCloud log (data/owncloud.log) ``` Insert your ownCloud log here ``` \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Mount\\\/MountPoint.php(257): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->getCache()\\n#10 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Config\\\/UserMountCache.php(89): OC\\\\Files\\\\Mount\\\\MountPoint->getStorageRootId()\\n#11 [internal function]: OC\\\\Files\\\\Config\\\\UserMountCache->OC\\\\Files\\\\Config\\\\{closure}(Object(OC\\\\Files\\\\Mount\\\\MountPoint))\\n#12 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Config\\\/UserMountCache.php(94): array_map(Object(Closure), Array)\\n#13 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Config\\\/MountProviderCollection.php(134): OC\\\\Files\\\\Config\\\\UserMountCache->registerMounts(Object(OC\\\\User\\\\User), Array)\\n#14 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Filesystem.php(448): OC\\\\Files\\\\Config\\\\MountProviderCollection->registerMounts(Object(OC\\\\User\\\\User), Array)\\n#15 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Filesystem.php(374): OC\\\\Files\\\\Filesystem::initMountPoints('admin')\\n#16 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/legacy\\\/util.php(294): OC\\\\Files\\\\Filesystem::init('admin', '\\\/admin\\\/files')\\n#17 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Utils\\\/Scanner.php(101): OC_Util::setupFS('admin')\\n#18 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Utils\\\/Scanner.php(137): OC\\\\Files\\\\Utils\\\\Scanner->getMounts('')\\n#19 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files\\\/lib\\\/BackgroundJob\\\/ScanFiles.php(87): OC\\\\Files\\\\Utils\\\\Scanner->backgroundScan('')\\n#20 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files\\\/lib\\\/BackgroundJob\\\/ScanFiles.php(111): OCA\\\\Files\\\\BackgroundJob\\\\ScanFiles->runScanner(Object(OC\\\\User\\\\User))\\n#21 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/BackgroundJob\\\/Job.php(57): OCA\\\\Files\\\\BackgroundJob\\\\ScanFiles->run(NULL)\\n#22 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/BackgroundJob\\\/TimedJob.php(53): OC\\\\BackgroundJob\\\\Job->execute(Object(OC\\\\BackgroundJob\\\\JobList), Object(OC\\\\Log))\\n#23 \\\/var\\\/www\\\/html\\\/owncloud\\\/cron.php(120): OC\\\\BackgroundJob\\\\TimedJob->execute(Object(OC\\\\BackgroundJob\\\\JobList), Object(OC\\\\Log))\\n#24 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Memcache\\\/Redis.php\",\"Line\":49}"} {"reqId":"KHwrUNxkDpWyWCOcRzE8","level":3,"time":"2019-03-12T12:29:01+00:00","remoteAddr":"","user":"--","app":"PHP","method":"--","url":"--","message":"Redis::connect(): connect() failed: php_network_getaddresses: getaddrinfo failed: Name or service not known at \/var\/www\/html\/owncloud\/lib\/private\/RedisFactory.php#81"} {"reqId":"2Jb7NXScVYBj2iUWdD6P","level":3,"time":"2019-03-12T12:30:01+00:00","remoteAddr":"","user":"--","app":"PHP","method":"--","url":"--","message":"Redis::connect(): connect() failed: php_network_getaddresses: getaddrinfo failed: Name or service not known at \/var\/www\/html\/owncloud\/lib\/private\/RedisFactory.php#81"} {"reqId":"OOGfGWOgDNzEOhwvmWKV","level":3,"time":"2019-03-12T12:31:02+00:00","remoteAddr":"","user":"--","app":"PHP","method":"--","url":"--","message":"Redis::connect(): connect() failed: php_network_getaddresses: getaddrinfo failed: Name or service not known at \/var\/www\/html\/owncloud\/lib\/private\/RedisFactory.php#81"} {"reqId":"AockyLToiwUqlNGFPTY4","level":3,"time":"2019-03-12T12:32:01+00:00","remoteAddr":"","user":"--","app":"PHP","method":"--","url":"--","message":"Redis::connect(): connect() failed: php_network_getaddresses: getaddrinfo failed: Name or service not known at \/var\/www\/html\/owncloud\/lib\/private\/RedisFactory.php#81"} {"reqId":"228r95juytl8MDz3mzxN","level":3,"time":"2019-03-12T12:33:01+00:00","remoteAddr":"","user":"--","app":"PHP","method":"--","url":"--","message":"Redis::connect(): connect() failed: php_network_getaddresses: getaddrinfo failed: Name or service not known at \/var\/www\/html\/owncloud\/lib\/private\/RedisFactory.php#81"} {"reqId":"0OQ6cyL2ITceMvA5XSxW","level":3,"time":"2019-03-12T12:34:02+00:00","remoteAddr":"","user":"--","app":"PHP","method":"--","url":"--","message":"Redis::connect(): connect() failed: php_network_getaddresses: getaddrinfo failed: Name or service not known at \/var\/www\/html\/owncloud\/lib\/private\/RedisFactory.php#81"} {"reqId":"8qhsjIv7DqAi50T4xtgv","level":3,"time":"2019-03-12T12:35:01+00:00","remoteAddr":"","user":"--","app":"PHP","method":"--","url":"--","message":"Redis::connect(): connect() failed: php_network_getaddresses: getaddrinfo failed: Name or service not known at \/var\/www\/html\/owncloud\/lib\/private\/RedisFactory.php#81"} #### Browser log ``` Insert your browser log here, this could for example include: a) The javascript console log b) The network log c) ... ```
