1.Tarball extracted in /var/www/html
entered http://example.com/owncloud
2.
3.
Please note: this server is already running a wordpress app with php7.2 and mariadb10.1 successfully
signing owncloud page to initiate installation
get a white page
get this info in /var/log/apache2/error.log
[Mon Mar 11 12:49:09.366870 2019] [php7:error] [pid 22738] [client xxx.xxx.xxx.xxx:38140] PHP Fatal error: Uncaught Error: Call to a
member function getLogger() on null in /var/www/html/owncloud/index.php:86\nStack trace:\n#0 {main}\n thrown in /var/www/html/owncloud/index.php on line 86, referer: https://nnnnnnnnn.org/
Operating system: debian 9.7
**Web server:**apache 2.4
**Database:**mariadb 10.1
**PHP version:**7.2
ownCloud version: (see ownCloud admin page)10.1
**Updated from an older ownCloud or fresh install:**fresh
**Where did you install ownCloud from:**tarball
Signing status (ownCloud 9.0 and above):??
christian@APRINA:/var/www/html/owncloud$ sudo -u www-data php occ config:list system
[sudo] Mot de passe de christian :
Error: Class 'RedisCluster' not found in /var/www/html/owncloud/config/config.php:991
Stack trace:
#0 /var/www/html/owncloud/lib/private/Config.php(266): include()
#1 /var/www/html/owncloud/lib/private/Config.php(64): OC\Config->readData()
#2 /var/www/html/owncloud/lib/base.php(134): OC\Config->__construct('/var/www/html/o...')
#3 /var/www/html/owncloud/lib/base.php(515): OC::initPaths()
#4 /var/www/html/owncloud/lib/base.php(994): OC::init()
#5 /var/www/html/owncloud/console.php(64): require_once('/var/www/html/o...')
#6 /var/www/html/owncloud/occ(11): require_once('/var/www/html/o...')
#7 {main}
**List of activated apps:**none
SELECT * FROM oc_appconfig
WHERE appid
= ‘user_ldap’;
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
c) …
