1.Create new fresh install over php 7.1
2.Select mariaDB database
3.Enter an admin user and password
You can make further logins with supplied user and password
You can’t login with that user/password.
Credentials table is empty.
Adding an email to the user row at “users” table does not allow you to get a recovery email.
Unknown. I’m on a mobile and can’t check now.
10.2.0, installed today from last production download.
Fresh install
your #%+ page.
Can’t login, as stated before.
Stock config php
