HTTP/1.1 200 OK
Server: nginx/1.10.1
Date: Fri, 02 Sep 2016 07:39:52 GMT
Content-Type: application/xml
Transfer-Encoding: chunked
Connection: keep-alive
X-Powered-By: PHP/5.6.24
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
X-XSS-Protection: 1; mode=block
X-Content-Type-Options: nosniff
X-Frame-Options: Sameorigin
X-Robots-Tag: none
X-Download-Options: noopen
X-Permitted-Cross-Domain-Policies: none
Content-Security-Policy: default-src ‘none’;
Set-Cookie: oc_username=deleted; expires=Thu, 01-Jan-1970 00:00:01 GMT; Max-Age=0; secure; httponly
Set-Cookie: oc_token=deleted; expires=Thu, 01-Jan-1970 00:00:01 GMT; Max-Age=0; secure; httponly
Set-Cookie: oc_remember_login=deleted; expires=Thu, 01-Jan-1970 00:00:01 GMT; Max-Age=0; secure; httponly
Set-Cookie: oc_username=deleted; expires=Thu, 01-Jan-1970 00:00:01 GMT; Max-Age=0; path=/; secure; httponly
Set-Cookie: oc_token=deleted; expires=Thu, 01-Jan-1970 00:00:01 GMT; Max-Age=0; path=/; secure; httponly
Set-Cookie: oc_remember_login=deleted; expires=Thu, 01-Jan-1970 00:00:01 GMT; Max-Age=0; path=/; secure; httponly
Set-Cookie: ocheidkowxnr=kcdqkd0d494jo3ebq9f85q7c93; path=/; secure; HttpOnly
1f2
<?xml version="1.0" encoding="utf-8"?><cal:schedule-response xmlns:d=“DAV:” xmlns:s=“sabre/dav” xmlns:cal=“urn:ietf:params:xml:ns:caldav” xmlns:cs=“Calendar and Contacts Server” xmlns:card=“urn:ietf:params:xml:ns:carddav” xmlns:oc=“http://owncloud.org/ns”>
cal:response
cal:recipient
<d:href>mailto:damian@round.pl</d:href>
</cal:recipient>
cal:request-status3.7;Could not find principal</cal:request-status>
</cal:response>
</cal:schedule-response>
Someone help me?
