first of all I'm new to owncloud. I have installed the 10.0.0.4 appliance to VMware ESX.
I have 2 questions: How do I update to the newer version? The documentation states directories that I cannot find inside the appliance. The Updater Plugin is not available.
Is it possible to replace the self signed certificate with a wildcard certificate? I have serched the documentation but cannot find the certificate button inside owncloud.
You update the ownCloud app as soon as a new version ist released. The web updater us disabled because it is not the intended way to update ownCloud on a host system.
You now have the newest app.
The 10.0.7 app will be released as soon as it has been tested.
You can replace the certificates, I can send you the two commands you need to do that.
There is a separate doc for the appliance inside the ownCloud doc
