Hello, I am new to ownCloud and am exploring the platform.
I have setup the web app and an android application. After testing the app, I am trying to figure how the architecture is setup. I am starting with one of the simple operations for file deletion. I am trying to understand where in the owncloud web app does file deletion take place.
Using wireshark I can see that file deletion triggers the following request from the ciient:
DELETE /owncloud/remote.php/webdav/file-path
Based on my investigation so far, I see the following (perhaps) relevant php files that contain the deletion logic:
owncloud/3rdparty/sabre/dav/lib/DAV/
1. CorePlugin.php - httpDelete() method
2. TemporaryFileFilterPlugin.php - httpDelete() method
Are any of the above files part of the right control flow to handle a file delete requested by a client ?
Thanks.
