Im running latest OC.. Think its 9.
Hardware: Raspberry Pi 2
OS: Raspbrian jessie lite
1: Used Petrockblogs script to install OC.
2: Mount usb drive formatted as NTFS
3: rsync the /var/www/html/owncloud/data /media/owncloud
4: edit /var/www/html/owncloud/config/config.php and change the data path to /media/owncloud/data
5: Load the owncloud website and see it NOT working (it works if i use the original data folder path)
6: Try not to cry
7: Cry.. Alot
Expected behavior: Ownclouds website loading up
Actual behavior: A plain text with the following:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
Nothing of value showing up in the logs though.
