ownCloud not working with specific browsers
#1
I have the very latest stable ownCloud version. I can access anything from Safari on a MacOS, IE on Windows and that's about it. I cannot use Chrome, Firefox or Edge. When I try to login, it just doesn't recognise the arrow button.
No errors in the logs, no errors or tips anywhere. Everything looks good!
Any ideas?
Thanks!
#2
Have a look at e.g.:
#3
Thanks! I host it on a VPS with CentOS 6.8 but I don't see why javascript could suddenly be disable. I read the same question as well. Also it works on Safari and IE. Maybe because these browsers dont have as good security as Chrome and Firefox?
#4
Also check ad-blockers and anti-virus extensions. The browser console can help you if resources can't be loaded or other errors occur.
