i installed owncloud. But my files are not uploading. How to correct this issue ?
Is this dataabase setup issue or cache setup issue ? I followed instructions of documentations but either commands or folders are not as per documentation.
Plz resolve it asap.
Regards,
Are you using external storage, if yes which one: local/smb/sftp/âŚ
Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/âŚ
