- Upgrading 10.0.0 to 10.0.4
2.
3.
Smooth upgrade
Seems to hang on "Repiar Info: Fetching app from market: actvity".
Database size grows uncontrolably during this time, filling up the entire disk
CentOS 7
Apache
mariadb
PHP 5.6
10.0.0
Fresh
https://download.owncloud.org/community/
Are you using external storage, if yes which one: local/smb/sftp/...
Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/...
