Hello all,
I started a new fresh installation of owncloud univention appliance some days ago, I configured my public domain with the public IP of my firewall (Sophos UTM 9 virtual appliance) and I added a WAF configuration to access my onwcloud server.
But it’s not working, I have continuously the trusted domain error message but my domain and the public IP are set into the config.php file.
I should have access to owncloud from outside
I have the error message :
You are accessing this server with an untrusted domain.
Please contact your administrator. If you are an administrator of this instance, configure the “trusted_domains” setting in config/config.php. …
UCS Version: 4.3-3 errata410
UMC Version : 10.0.6-18A~4.3.0.201901151044
Web server: apache2
Database: mysql
PHP version: php 7.x
ownCloud version: (see ownCloud admin page) 10.0.10.4
“config”: {
“apps_paths”: [
“path”: “/var/www/owncloud/apps”,
“url”: “/apps”,
“writable”: false
“path”: “/var/www/owncloud/custom”,
“url”: “/custom”,
“writable”: true
“trusted_domains”: [
“cloud.mydomain.net”
“datadirectory”: “/var/lib/univention-appcenter/apps/owncloud/data/files”,
“dbtype”: “mysql”,
“dbhost”: “172.17.42.1:3306”,
“dbname”: “owncloud”,
“dbtableprefix”: “oc_”,
“log_type”: “owncloud”,
“supportedDatabases”: [
“sqlite”,
“mysql”,
“pgsql”
“upgrade.disable-web”: true,
“default_language”: “fr”,
“overwrite.cli.url”: “http://cloud.mydomain.net/owncloud”,
“htaccess.RewriteBase”: “/owncloud”,
“logfile”: “/var/lib/univention-appcenter/apps/owncloud/data/files/owncloud.log”,
“loglevel”: 2,
“memcache.local”: “\OC\Memcache\APCu”,
“filelocking.enabled”: true,
“version”: “10.0.10.4”,
“logtimezone”: “UTC”,
“installed”: true,
“instanceid”: “octy6gxpgen3”,
“log_rotate_size”: 104857600,
“onlyoffice”: {
“verify_peer_off”: true
“trusted_proxies”: [
“172.17.42.1”
There is no application installed yet
No external storage used
Are you using encryption: no
Browser: Chrome - Edge - Firefox
Operating system: Windows
{"reqId":"mR446UHoQ32WjhSfmnP9","level":2,"time":"2019-01-29T21:50:18+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"08efctfudlbhWs7LcXk2","level":2,"time":"2019-01-29T21:50:19+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=dc144562d9252b20c8c59b2ed91037a2","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"QJFnuQIWoD3qq1snQ2Fb","level":2,"time":"2019-01-29T21:55:36+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"IjeUqqlQ7yNyx2YouKxR","level":2,"time":"2019-01-29T21:55:36+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=dc144562d9252b20c8c59b2ed91037a2","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"Kk8JTD4Mi57GgYtaEr9j","level":2,"time":"2019-01-29T21:55:38+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"KlsHC1r8oZQ2xQTENl7b","level":2,"time":"2019-01-29T21:55:39+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=dc144562d9252b20c8c59b2ed91037a2","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"9de8brttaYJYOxVYZhKu","level":2,"time":"2019-01-29T21:55:40+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"NxD2xRQSwBrcgLi2FsjJ","level":2,"time":"2019-01-29T21:55:40+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=dc144562d9252b20c8c59b2ed91037a2","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"2OJl6rYU7sr1M40zW4jr","level":2,"time":"2019-01-29T22:01:33+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"bV8qdWOoba3FfDVOfSEZ","level":2,"time":"2019-01-29T22:01:33+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=dc144562d9252b20c8c59b2ed91037a2","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"6a7BdXMfUVyKAOF9K4JH","level":2,"time":"2019-01-29T22:02:28+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"PPBlUOFVoOyWGqQ8J4Zq","level":2,"time":"2019-01-29T22:02:29+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=dc144562d9252b20c8c59b2ed91037a2","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"i8XQmYEvKR1kHcDvv8Wb","level":2,"time":"2019-01-29T22:02:39+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"1cXRgO3dynfeD2OKUVby","level":2,"time":"2019-01-29T22:02:39+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=dc144562d9252b20c8c59b2ed91037a2","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"68gxJfiAn1sJuPz1vHk5","level":2,"time":"2019-01-29T22:03:49+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"CpHcckq6NBruTBGy3six","level":2,"time":"2019-01-29T22:03:49+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=dc144562d9252b20c8c59b2ed91037a2","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"3uj24b3ULpCs9v4H5DEk","level":2,"time":"2019-01-29T22:04:21+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"WnxLAMq1cTWEGx23a3KZ","level":2,"time":"2019-01-29T22:04:22+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=dc144562d9252b20c8c59b2ed91037a2","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"0gH221I4JvCPepzJsL0w","level":2,"time":"2019-01-29T22:19:22+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"aQd5Jf4wOlWTHlh4qliM","level":2,"time":"2019-01-29T22:34:22+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"QLGpry187KvutkAPEtzg","level":2,"time":"2019-01-29T22:49:23+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"mE6GigPjKOBbWetuwveC","level":2,"time":"2019-01-29T23:04:23+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"j4IhbjzRLCy1CkZhA9f6","level":2,"time":"2019-01-29T23:19:24+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"G8xrUji4192D2QK2kHCz","level":2,"time":"2019-01-29T23:34:24+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"akhzN6g3seGVWcq9yjwF","level":2,"time":"2019-01-29T23:49:24+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"a0LkXHvbhyFiIdMwyrK9","level":2,"time":"2019-01-30T00:04:25+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"FAuF5kCo1VBci3RRaAYB","level":2,"time":"2019-01-30T13:50:00+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"PFiZRTsOzJ0A220nmxg1","level":2,"time":"2019-01-30T14:05:01+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"FfpN81JmLnYWKQdb08l6","level":2,"time":"2019-01-30T14:20:02+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"2XmZj0duo7BpTUw7AzVX","level":2,"time":"2019-01-30T14:35:04+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"PeIkR0BbppZaY9W98sLW","level":2,"time":"2019-01-30T14:50:04+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"xsRBNWNPhMiHJ10INU6q","level":2,"time":"2019-01-30T15:05:10+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"AjVAphmX39WQKpgvvdJo","level":2,"time":"2019-01-30T15:20:11+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"oL49zGhXj0dIZCsRrK8r","level":2,"time":"2019-01-30T15:35:11+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"3vpFCBvQnViNQE7OTYX1","level":2,"time":"2019-01-30T15:50:12+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"EoPa6hvOEcApCA3xCRsu","level":2,"time":"2019-01-30T16:05:14+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"cKncInxhgeMjMU0lNrzB","level":2,"time":"2019-01-30T16:20:15+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"ehtXpMpPFZjMudQ4lMBy","level":2,"time":"2019-01-30T16:22:08+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"sQcntdkQa01YGKbsTVOZ","level":2,"time":"2019-01-30T16:22:09+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=dc144562d9252b20c8c59b2ed91037a2","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"OcAvVDmahV0koczlfya7","level":2,"time":"2019-01-30T16:22:14+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"HzifCrnntAAhykSW6i1V","level":2,"time":"2019-01-30T16:22:15+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/core\/js\/oc.js?v=dc144562d9252b20c8c59b2ed91037a2","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"kOiuJWh5YgRpTZiulEeW","level":2,"time":"2019-01-30T16:22:17+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"GET","url":"\/owncloud\/","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"Z0Q4znLauPUwZHxrx76A","level":2,"time":"2019-01-30T16:37:16+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"4QzhsqZGfj8dwATXwiDB","level":2,"time":"2019-01-30T16:52:19+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"X3XKoE5qlNZPpa69VE6C","level":2,"time":"2019-01-30T17:07:21+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"70UhPwFaBgNWHLLBB53c","level":2,"time":"2019-01-30T17:22:22+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"xJRaS7KiEWWvkeNmVTkx","level":2,"time":"2019-01-30T17:37:22+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
{"reqId":"pqVeaOtLLLvKH0sC9u3H","level":2,"time":"2019-01-30T17:52:22+00:00","remoteAddr":"1.2.3.4","user":"--","app":"core","method":"POST","url":"\/owncloud\/index.php\/heartbeat","message":"Trusted domain error. \"1.2.3.4\" tried to access using \"cloud.mydomain.net\" as host."}
