I try to exclude some folders from the sync with owncloudcmd on Linux.
I try to exclude the folder “fotos”.
How must an entry look like for this folder?
File should look like this:
https://github.com/owncloud/client/blob/master/sync-exclude.lst
Here you can find more information:
The Command Line Client :: ownCloud Documentation
The manpage is not very usefull
What is the “]” for? Is that Regex?
This are rules for files, not for folders. Are the pathes for folders relative or absolut?
Here you can find the detailed patterns:
