Problem Dependency check
It installs the owncloud version 10 again and after trying to install it with the Web Installer, it displays the message "Dependency check Dependencies not found.
The following PHP modules are required to use ownCloud:
zip
GD
curl
Please contact your server administrator to install the missing modules. "
I do not know what’s going on. I checked the php version and I have 7.
Please help.
can you try to install them on your OS?
if you have Ubuntu for exampe:
apt install zip
Also you can always look in the doc for clues:
https://doc.owncloud.com/server/10.0/admin_manual/installation/source_installation.html#install-the-required-packages
Thank you for your help but unfortunately it did not help. I have an openmediavault system on Debian. Next displays the information Dependency check
zip
GD
curl
Managed to. The missing php packages had to be installed.
When creating the user, there is a 504 Gateway Time-out error. Does anyone know why?
I think this new issue deserves a new thread with a detailed description of your new issue.
ok, I’m doing it now
