Can you run the following command by connecting to your server via SSH as root: occ status
Do you have single user mode enabled?
Can you check your ownCloud and apache logs?
Do you have any third party apps enabled?
When creating a server issue there is a template. It is vital for you to fill this out as it helps the forum members to help you effectively. And it already asks all the important questions, I now have to ask you again…
