well the error is quite straightforward, the table oc_appconfig exists.
It lacks a lot of information here, did you restore a SQL dump ? Did you drop the database first ?
Please give use all the informations, we don’t know what you did and can’t/don’t want to guess it all.
I know the template might not be useful in this case, but the ownCloud version, what was the reinstallation process etc … is mandatory here.
Thanks.
Hi, as I said before, I performed both the backup and the recovery from the graphical interface (via phpmyadmin) the version of owncloud is the 10.3.0.4
When I backed up the database under: Object creation options I selected: Add the DROP DATABASE IF EXISTS statement
Add the instruction DROP TABLE / VIEW / PROCEDURE / FUNCTION / EVENT / TRIGGER
Add the CREATE TABLE statement
IF NOT EXISTS (less efficient because the indexes are generated during the creation of the table)
I have reinserted the data folder with the usual command, the db (as already mentioned) from the phpmydmin graphical interface, from the terminal if I enter the data folder and in the user I see all the files present
