Problem to Sync Contact with Carddav Sync Free (Android)
Hi, people.
I've start using Owncloud and i create few contact;
I use carddav sync free on android mobile.
But i have got this error in the access.log of apache2
192.168.112.71 - jeremy [01/Mar/2018:10:50:59 +0100] "PROPFIND /owncloud/remote.php/carddav/principals/jeremy/ HTTP/1.1" 207 1355 "-" "CardDAV-Sync free/0.4.21 (Xiaomi; santoni; Android 7.1.2; fr_FR; org.dmfs.carddav.sync/143)"
192.168.112.71 - - [01/Mar/2018:10:50:59 +0100] "PROPFIND /owncloud/remote.php/carddav/principals/jeremy/ HTTP/1.1" 401 1230 "-" "CardDAV-Sync free/0.4.21 (Xiaomi; santoni; Android 7.1.2; fr_FR; org.dmfs.carddav.sync/143)"
192.168.112.71 - jeremy [01/Mar/2018:10:50:59 +0100] "PROPFIND /owncloud/remote.php/carddav/principals/jeremy/ HTTP/1.1" 207 1297 "-" "CardDAV-Sync free/0.4.21 (Xiaomi; santoni; Android 7.1.2; fr_FR; org.dmfs.carddav.sync/143)"
I use this url in carddav : http://ipaddressowncloud/owncloud/remote.php/dav/addressbooks/users/jeremy/contacts/
Can you help me please ? :slight_smile:
Thanks you
which version are you using?
I use owncloud 10.0.2.1
update to 10.0.7 please
i have update to 10.0.7 but i have the following message : this owncloud instance is currently in maintenance mode, which may take a while....
please follow the docs on how to change maintenance mode
okey, is it a problem if i use a debian for install owncloud ?
thanks you for your answer
i have got always the error 401 in the acess.log of apache2..
I see PROPFIND 401 and OPTIONS 401 errors in my logfile too. But the cloud works fine. Seems to be normal. I am using the URL /remote.php/dav/addressbooks/users/username/addressbookname to sync. Does syncing work in your setup? Maybe the problem is not this 401 error.
No it doesn’t work.
192.168.112.73 - - [16/May/2018:09:39:46 +0200] “PROPFIND /owncloud/remote.php/dav/addressbooks/users/jeremy/ HTTP/1.1” 401 1339 “-” “CardDAV-Sync free/0.4.21 (Xiaomi; santoni; Android 7.1.2; fr_FR; org.dmfs.carddav.sync/143)”
I’ve got the lastest version of owncloud.
i make a test with an Iphone and it’s okey.
I can sync contact.
But with android smartphone i can’t.
I make tests with carddav sync free and davdroid…
Can you help me please…
I solve my problem.
Thanks you everybody
Hey, nice to hear. Could you share the solution as thread ending with “i solve my problem” without describing what was done to solve it can get frustrating for other users having a similar issue.
