I have updated my Ubuntu version from 16.04 to 18.04
I then changed ‘deb http://download.owncloud.org/download/repositories/stable/Ubuntu_16.04/ /’ to ‘deb http://download.owncloud.org/download/repositories/stable/Ubuntu_18.04/ /’ in sources.list and did apt update.
‘<?php phpinfo(); ?>’ shows /etc/php/7.1/apache2
When I got to my owncloud URL I get
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times and include the technical details below in your report.
Technical details
Remote Address: 84.17.53.159
Request ID: TJSfs0K0LkHI1MP6lzpB
But cant find anything in the Apache logs.
Any ideas?
Ben
Ubuntu 18.4
apache2.4
MariaDB 10.1
Can’t access admin page
from old ver
