Hello! Enroll persistent errors in the. Can anyone met such.
1.problems with LDAP after updating owncloud 9.1.6 to version 10.0.3
owncloud.log shows many errors of the type:
{"reqId":"nbqkIe3lhdaOEERxHSjw","level":3,"time":"2017-10-29T19:14:45+03:00","remoteAddr":"46.191.100.115","user":"--","app":"user_ldap","method":"POST","url":"\/index.php\/login","message":"Exception: {\"Exception\":\"Exception\",\"Message\":\"No user available for the given login name on 192.168.1.20:389\",\"Code\":0,\"Trace\":\"#0 \\/var\\/www\\/html\\/owncloud\\/apps\\/user_ldap\\/lib\\/User_LDAP.php(117): OCA\\User_LDAP\\User_LDAP->getLDAPUserByLoginName('ean')\n#1 [internal function]: OCA\\User_LDAP\\User_LDAP->checkPassword(*** sensitive parameters replaced )\n#2 \\/var\\/www\\/html\\/owncloud\\/apps\\/user_ldap\\/lib\\/User_Proxy.php(79): call_user_func_array(Array, Array)\n#3 \\/var\\/www\\/html\\/owncloud\\/apps\\/user_ldap\\/lib\\/Proxy.php(140): OCA\\User_LDAP\\User_Proxy->walkBackends('ean', 'checkPassword', Array)\n#4 \\/var\\/www\\/html\\/owncloud\\/apps\\/user_ldap\\/lib\\/User_Proxy.php(194): OCA\\User_LDAP\\Proxy->handleRequest('ean', 'checkPassword', Array)\n#5 \\/var\\/www\\/html\\/owncloud\\/lib\\/private\\/User\\/Manager.php(215): OCA\\User_LDAP\\User_Proxy->checkPassword( sensitive parameters replaced )\n#6 \\/var\\/www\\/html\\/owncloud\\/lib\\/private\\/User\\/Session.php(467): OC\\User\\Manager->checkPassword( sensitive parameters replaced )\n#7 \\/var\\/www\\/html\\/owncloud\\/lib\\/private\\/User\\/Session.php(301): OC\\User\\Session->loginWithPassword( sensitive parameters replaced )\n#8 \\/var\\/www\\/html\\/owncloud\\/core\\/Controller\\/LoginController.php(201): OC\\User\\Session->login( sensitive parameters replaced )\n#9 [internal function]: OC\\Core\\Controller\\LoginController->tryLogin( sensitive parameters replaced ***)\n#10 \\/var\\/www\\/html\\/owncloud\\/lib\\/private\\/AppFramework\\/Http\\/Dispatcher.php(159): call_user_func_array(Array, Array)\n#11 \\/var\\/www\\/html\\/owncloud\\/lib\\/private\\/AppFramework\\/Http\\/Dispatcher.php(89): OC\\AppFramework\\Http\\Dispatcher->executeController(Object(OC\\Core\\Controller\\LoginController), 'tryLogin')\n#12 \\/var\\/www\\/html\\/owncloud\\/lib\\/private\\/AppFramework\\/App.php(98): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OC\\Core\\Controller\\LoginController), 'tryLogin')\n#13 \\/var\\/www\\/html\\/owncloud\\/lib\\/private\\/AppFramework\\/Routing\\/RouteActionHandler.php(46): OC\\AppFramework\\App::main('LoginController', 'tryLogin', Object(OC\\AppFramework\\DependencyInjection\\DIContainer), Array)\n#14 [internal function]: OC\\AppFramework\\Routing\\RouteActionHandler->_invoke(Array)\n#15 \\/var\\/www\\/html\\/owncloud\\/lib\\/private\\/Route\\/Router.php(307): calluser_func(Object(OC\\AppFramework\\Routing\\RouteActionHandler), Array)\n#16 \\/var\\/www\\/html\\/owncloud\\/lib\\/base.php(928): OC\\Route\\Router->match('\\/login')\n#17 \\/var\\/www\\/html\\/owncloud\\/index.php(56): OC::handleRequest()\n#18 {main}\",\"File\":\"\\/var\\/www\\/html\\/owncloud\\/apps\\/user_ldap\\/lib\\/User_LDAP.php\",\"Line\":101}"}
"user_ldap" 0.9.1
Operating system: Ubuntu Server 15.10
Web server:Apache/2.4.12
Database:mariaDB 10.0.25
PHP version:PHP 5.6.11
ownCloud version (see ownCloud admin page): ownCloud 10.0.3 (stable)
Special configuration (external storage - nas, external authentication- ldap, reverse proxy - no, server-side-encryption-no):
