Hi, I have a problem with login page.
After a manual upgrade to Owncloud 10.8.0.4 on a Debian 10 sever, I cannot reach the login page as usual: pointing at https://MYSITE/owncloud results in showing the index.php file and not the usual login mask with the wallpaper of Owncloud X.
Anyone can help me?
Thank you in advance,
G
I solved my problem…
Firstly I found that mod_php module of Apache2 was NOT enabled (and I enabled it using a2enmod command). Then I made a fresh manual re-upgrade to Owncloud 10.8.0.4 following exactly what is said at https://doc.owncloud.com/server/admin_manual/maintenance/upgrade.html.
Thanks anyway
G
