Hi All,
I have problem with opening images, i alredy have installed the gallery app, but i have this error:
“could not generate a preview of this file owncloud”, and i have only black screen with this errors!
Hi All,
Do you have encryption?
Hi Dmitry,
We don’t use encryption.
Thanks,
Okay, some information about your system would be great to help you
I was use owncloud 9.1.8 version, with sqlite as a db. its running on hosting not vps
When was the problem detected?
after update of owncloud from version 9.1.4 to 9.1.8, then the galery not working
9.1 is out of Life = not loger supported.
Please update to 10
9.1 2016-07-21 2018-02 9.1.8 (2018-03-14) End of Life
The image gallery does not show the images in my owndcloud 10.3.2.2
The new files_mediaviewer app doesn’t have a gallery feature. Reinstall the gallery app and check the release notes:
https://doc.owncloud.org/server/10.4/admin_manual/release_notes.html#media-viewer-replaces-gallery-and-video-player
Edit: I just noticed this thread is 1.5 years old, about an ownCloud version that was back then already EOL. Please don’t revive these super old threads. — closed
