Woju
September 1, 2021, 5:44pm
1
Problem with showing the image / thumbnails .pdf in the form like png, jpg in the details section
In config.php the preview parameters are set and they work fine for png and jpg files. For pdf type it generates thumbnails correctly, but always in the size of 150x150 and does not accept parameters from the config file. Below are snapshots.
alfredb
September 2, 2021, 1:52pm
2
Interesting. I wasn’t aware of that configuration options. Unfortunately, I don’t have any solution for your issue.
tom42
September 2, 2021, 5:15pm
3
i think it could help if you could provide at least the installed ownCloud version.
Woju
September 2, 2021, 6:26pm
4
I think I have the current version. Does it make sense to check with a beta or other version?
version
10.8.0.4
versionstring
10.8.0
edition
Community
Woju
September 2, 2021, 6:31pm
5
You can check on your own cloud, do you have a similar effect with pdf and png / jpg?
alfredb
September 2, 2021, 6:42pm
6
I did already. I couldn’t create any larger preview images from PDF files. But I’ll stop here, I don’t have the time for diving deeper.
Woju
September 2, 2021, 10:08pm
7
You must start imagemagick on your server or use onlyoffice to convert pdf
system
Closed
December 1, 2021, 10:09pm
8
